I bought a Oliver 77 today, but got a enging question....
Low96hb
The guy told me the engine had been changed out by his dad, but was unsure what the motor was and his father had passed away. Where can I find a guide to the casting numbers on the block? Im sure this has been beat to death on this topic, but im new to olivers...... :?:
Since you are new to an Oliver did you buy a 77 or a Super 77? Do you have a tractor serial number? It will be on a plate on the dash or below the platform more or less below the gear shift lever if it is before say mid 1952. Also the 185 number is for a block that should be in a 77 series. There will also be a 1M100 type number. What is the complete casting number?
its a 77 engine. J should be able to tell you the exact year. I know its around the same age as the tractor.
