Over/Under Hydraulic Lines
I'm tring to get my 1950-T back going again after a rebuild and something has happened to my hydraulic lines that cool the over/under. I can't seem to find them anywhere, I don't know if someone in the shop threw them away or what. DOes anyone know where I could locate some of these? Are they the same as maybe a set on a White 2-70? I've got a junked 2-70 that has a set on it. Anyway thanks guys.
check the salvage yards or bend your own out of brake line and the adapt or cut and put the correct fittings on.
Most implement dealers can make hydraulic hoses. Measure the length you need and try to find out what type of ends go in the existing fittings. I'm willing to bet its either 9/16 or 3/4 flare(jic) ends.
if you make hoses you will need 1/2 inverted flare ends that have a 45 degree bend and about 6' of hose on each one. single nylon braid hose works best.
