Hello Everyone and thanks in advance for help with the following problem:
Some of what I am about to say is likely bad guess-work, but is the best I have come up with so far.
I have the Gemmer Hydraguide from an Oliver 770 tractor with the 778 Loader. Problem is steering is slipping on turns which I believe to be caused by broken helix gear splines.
I bought a replacement unit, but this "new" unit has the center spool reversed. It is also yellow, which I am guessing means it likely came off a Cockshutt.
What I cannot find out, and hope to have help with, is information on assembly/disassembly.
Is the sleeve press-fit into the housing? Does the helix gear shaft need to be removed - and how?
Basically, any reference or info on disassembly would be appreciated. Thanks.
Charlie
Charlie
