Irv, Phil, others:
I know the headgasket for the 50D is as rare as hens teeth. Mine blew today spraying antifreeze out of the block and hydro locked it. I hope when it did nothing was bent in the engine. However, it does turn over now that the injectors are pulled and the antifreeze is out. Isn't there a gasket that can be alerted to fit? Though it doesn't work that well?
Any suggestions what I should do?
I am still filling sick and discussed. But that's life when you play with old tractors I guess.
