Need a little help with my hydraulics on a late model 1850.
When I bought it it only had remotes on the right side put a set of couplers on left side worked fine. But they seem to always have pressure on them very hard to hook up lines always have to shut tractor off and relieve pressure on remotes.
Then couplers started leaking past the ball noticed when activating right side would put pressure on left side remotes. With lines hooked up on both sides on field cultivator for lift and wings they work as they should.
It is a hydraelectric system the wires were cut when I bought it.
Assuming it's a valving problem can anyone lead me in the right direction?
Thank Al
Thank Al
