Hydraulic transmission oil again
JCP NC
10-18-2016 10:44:51
Yesterday I went to the local New Holland dealer and purchased the oil that they say they use in 8 N Fords.
The oil is Ambra Mastertran Ultraction hydraulic transmission oil
Mat 3540
I know all about the ford spec it's supposed to meet but it don't tell the specs. on the bucket.
Is this the right stuff for my little baby or not ? :? Thanks
Jack
soundguy
10-20-2016 07:23:53
 Re: Hydraulic transmission oil again in reply to JCP NC, 10-18-2016 10:44:51
It's easy to find generic UTF fluids at most part and farm stores in 5g pails.
If it costs between 35-50$ it's usually ok stuff.
Ocasionally you see some 20-25$ stuff, that while is ok in an old ford in warm climates, might not be fantastic in cold climates.
JCP NC
10-19-2016 06:00:25
Thanks Tim
My bucket says (MAT 3540) which tell exactly what it is, what ever that is.
Jack
Tim Ploughnman Daley
10-18-2016 13:51:54
Older New Holland MC 134 Hydraulic Oil-
third party image
Newer New Holland MC 134D Hydraulic Oil-
third party image
Current Tractor Supply Oil-
third party image
The stuff TSC sells is going to be the cheapest, is actually just SAE-90 Gear Oil. Comes in 2 gallon jugs. Capacity of sump is 5 gallons but I never put that much in as it will leak out. Go slow, adding up to the full 4 gallons and keep checking often. It should be ok with 4 gallons.
Tim *PloughNman* Daley(MI)
JCP NC
10-18-2016 12:54:21
Thanks Dean, I can sleep better now knowing that I don't have to throw away that $80.00 bucket of oil.
Jack
Dean
10-18-2016 11:10:04
It is what CNH recommends not but not what was originally specified when these tractors were sold in the 1940s-1950s.
The CNH recommended oil performs much better, expecially in cold weather, but is somewhat more prone to leakage.
Dean
