Order Ford 8N Parts Online
9n parts tractor for 1950 8n
A.C.
05-26-2016 08:37:12
Guy says he has parts tractor for 300 bucks whole tractor and doesn't know whether it's a 9 or 8n. He supposed to send me pics. Question is is there 300 bucks of parts if it would happen to be a 9n that I can use on my side mount 8n?
Tim PloughNman Daley
05-27-2016 11:56:17
 Re: 9n parts tractor for 1950 8n in reply to A.C., 05-26-2016 08:37:12
I'd see exactly what this girl needs to bring her back to a working machine. If the block isn't cracked, see what it'll cost to restore, not necessary to original, but at least running, then maybe sell her and get more for it...
Tim *PloughNman* Daley(MI)
A.C.
05-27-2016 09:55:06
Guy sent pics. Looks like an early 8n.. he called said it's been setting a while just missing a lift arm and new rims on rear... looks like the parts tractor will be another project!!
soundguy
05-26-2016 12:12:28
as has been said. if you don't mind a mutt, and the donor has good parts.. you can do some mix n match. seat, fenders, rear tires and rims, the pump and top cover together will swap, the engine, radiator, pto shaft assembly, if it is the late assembly. if you start breaking it down, then parts from the rear center section.. though note the rear center will fit, but doesn't have drawbar tappings... etc.
tractorguy2
05-26-2016 11:08:15
If it is all there I would buy it. The last 8n parts tractor I saw brought $1000 at a farm sale. The owner tore the engine down to overhaul it and never finished. The engine was in several five gallon buckets.
Bhpony
05-26-2016 10:00:12
If it is 4-speed it is a 8n.
Ultradog MN
05-26-2016 08:42:23
No way to answer without knowing more about it. Many parts will fit - rear rims, tires, fenders - if you don't care about originality.
Worst case you cod part it out and take the $ to buy the parts you need.
I would do that deal.
