Order Ford 8N Parts Online
8n hydraulics problem
skipstein
05-18-2016 22:22:43
Hello All;
I am still trying to get the hydraulics working on my 8n. The sump is now clean and free of crud. The problem is I am not sure what to fix tio make it work, so; here are the actions I have taken so far: With the dip stick panel removed, if I move the valve arm connected to the lower end of the control arm 'manually', the hydraulics work and will hold a load. If i move the control arm from the rest position to the vertical position, nothing happens. I am not sure where to go from here. Is there a description of the various functions of the valves and moveable pieces within the 8n hydraulic pump? Or, can anyone point me in the right direction... help!
Thanks,
Skip
Royse
05-22-2016 15:45:29
 Re: 8n hydraulics problem in reply to skipstein, 05-18-2016 22:22:43
Your PTO must be running for the hydraulics to work.
The PTO shaft drives the pump. Clutch also has to be up/engaged.
If you can move the linkage manually and it works, I would
"assume" that both of those things are in tact.
There is a cork friction disk in the lift control handle.
Is your in place and in good condition?
Part #21 here
Clifford B.
05-22-2016 12:22:03
I suggest you buy or borrow an fo4 manual and read it !!
skipstein
05-22-2016 07:45:04
Hello All;
I am still trying to determine what needs to be repaired or adjusted on my 8n to get the hydraulics in order. I have heard, that if one removes the left side port (instead of the dip stick right port) there are PTO adjustments that must be done. I have never read anything about what these are and would these have anything to do with the functions of the hydraulics? The reason I ask is I do not want to tear something down without knowing I am going in the right direction. Any thoughts or suggestions are appreciated.
Thanks,
Skip
swpaguy
05-20-2016 05:18:04
That should be www.bramblett.com/zane/
swpaguy
05-20-2016 05:12:38
http://www.bramblett.com. that's his website.
JMOR
05-19-2016 06:57:03
Quoting Removed, click Modern View to seeA good starting point would be the manual, read & identify parts by name, so that readers of your post will be able to tell what you are talking about.
swpaguy
05-19-2016 06:32:10
I'm by far no expert but I'm currently working on mine. Sounds like the problem is with the linkage. Pull the top cover and inspect the linkage. Have the manual to help diagnose any problems and adjust it within specs. Check the cam follower pin. Also zane sells a jig to help get everything set just right. Is the control rod straight?
skipstein
05-19-2016 21:10:56
 Re: 8n hydraulics problem in reply to swpaguy, 05-19-2016 06:32:10
Hello;
Thanks for the suggestion. In this venue, I do not know how to get hold of Zane to talk to him about his hydraulic setup jig. If anyone can point me in the right direction, I would appreicate it.
Thanks,
Skip
ZANE
05-20-2016 16:23:21
 Re: 8n hydraulics problem in reply to skipstein, 05-19-2016 21:10:56
You can email me at wzsherman@aol.com
Thanks, Zane
