Pressure in radiator
billblaster201000
04-30-2016 04:12:27
My 9N started overheating now that the weather is getting warm. changed the radiator for new one; noticed air bubbles in radiator. What would crack first-head, or some other part of engine? I will check head first, but, is there some other weak spot in the engine design that I should be aware of?
billblaster201000
05-04-2016 03:14:46
 Re: Pressure in radiator in reply to billblaster201000, 04-30-2016 04:12:27
55 lbs seems to have fixed it. thanks for the advice.
arnold z
04-30-2016 13:56:24
After that, go back and tighten them to 55 ft lbs.
Dell (WA)
04-30-2016 11:57:53
Bill..... ...bubbles in the radiator water, eh? First thing I'd due is re-tighten all 18 head bolts to 40-ft/lbs. Simple, eh? Sometimes the head gasket takes a little bitt of heat to settle into place..... .HTH. the amazed Dell
HCooke
04-30-2016 06:34:59
Bubbles in rad could be head gasket failure. Do a compression test.
