Order Ford 8N Parts Online
8N Block
markgmurray
11-30-2015 15:17:06
1950 Ford 8N
Can a block be repaired if it has a crack / broken area behind the cylinder liner?
Thank you
Den N Ms
11-30-2015 16:59:38
 Re: 8N Block in reply to markgmurray, 11-30-2015 15:17:06
Mark,chances are it can be saved then,I have repaired and sleeved some cracked like that with no later problems.
Den N Ms
11-30-2015 16:04:47
Mark,That just depends on the location of the crack,at the top/middle or the bottom of the bore.If it is in the middle it can be with engine block cylinder sleeve sealer/retainer and new sleeve.The top or bottom would be harder to repair.Find a quality engine machine shop(that does sleeve replacement knows about such)and let them inspect the block.
markgmurray
11-30-2015 16:48:56
 Re: 8N Block in reply to Den N Ms, 11-30-2015 16:04:47
Thank you, it's cracked in the middle
