Order Ford 9N Parts Online
ford 9n lift
garr806
05-02-2015 07:21:05
Does a 9n tractirs 3pt lift has position control? Wherever you put the lever that is where the arm stop at.
howdy1960
05-02-2015 12:15:16
 Re: ford 9n lift in reply to garr806, 05-02-2015 07:21:05
Love mine, worth every cent!
Took me 15 minutes to install only cuz I kept going going back for right tools that I kept not getting. 300 ft each way LOL
Hint: get right sized wrenches while have part in hand while standing in front of tool box.
HCooke
05-02-2015 10:17:55
Here's a link to Zane's web site. His position control device installs on the outside of your tractor. Takes about 15 minutes to install and works very well.
ZANE
05-03-2015 07:18:56
 Re: ford 9n lift in reply to HCooke, 05-02-2015 10:17:55
Thanks,
Zane
garr806
05-02-2015 11:58:48
Thanks guys appreciate your help
Tim PloughNman Daley
05-02-2015 09:30:52
The 9N and 2N tractors only had draft control. It was the 8N that introduced the Position Control to the mix and the little lever under the right hand seat area is for setting those -UP for Position Control/DOWN for Draft Control. Longtime member here, Zane Sherman makes a gizmo he calls the 'Zane Thang' that will add position control to your 9N or 2N.
Tim *PloughNman* Daley(MI)
*9N653I* & *8NI55I3*
third party imagethird party image
garr806
05-03-2015 11:40:34
 Re: ford 9n lift in reply to Tim PloughNman Daley, 05-02-2015 09:30:52
Been trying to convince a friend what you said. But he insist that you should be able to control the height with the lever on a 9n/2n, also he says then why they have quadrant on the tractor if you can't set the height. I agree there is no position control on the 9n/2n. Can anyone explain the hydraulic system on a 9n/2n to me. I greatly appreciated it.
pikewi
05-02-2015 07:34:00
Nope. It can be added on tho
