Order Ford 8N Parts Online
8N won't crank
Bill Siano
08-24-2014 06:15:46
I installed a new 6 volt battery in my 8N. the tractor started and ran fine. I parked it, started it again with no problems. 2 hours later, the tractor is dead. It will not crank, and there is no spark. I bypassed the key switch and jumped right to the starter from a second vehicle with no success. the engine turns over, but no spark. does anyone have any ideas what to do next?
old
08-24-2014 07:55:43
 Re: 8N won't crank in reply to Bill Siano, 08-24-2014 06:15:46
Dead battery equals no spark so charge it up. #2 did you by chance leave the switch on?? If yes you may have burned up the points and or the coil
Bruce (VA)
08-24-2014 06:21:28
" anyone have any ideas what to do next?"
Charge the battery (see tip # 60) in the tractor.
Otherwise, no spark even w/ a jumper battery.
See tip # 43 before you jump it again.
Then, after that new battery is charged, check it. (tip # 49) The last battery I bought 2 years ago was bad from the store.
Lastly, find out why the battery drained so quickly (assuming it's good).
Did you leave the key on? (tip # 38)
