headlight wire
MnNC
05-16-2014 10:30:23
hello friends of the N
i removed headlight wire from behind dash
now trying to remember where to put it back
thinking it came off switch post....does that sound right? my N is a 2N with 12volt system. "46 Ford Ferguson with hi/lo trans. been a good "un :-)
Bruce (VA)
05-16-2014 10:39:44
 Re: headlight wire in reply to MnNC, 05-16-2014 10:30:23
If you wire it through the key switch, your next project will be to replace the key switch! It can't handle the current flow to the lights.
Wire it off of the lower (center) terminal on the terminal block.
MnNC
05-16-2014 10:47:04
 Re: headlight wire in reply to Bruce (VA), 05-16-2014 10:39:44
thanks Bruce ! knew i could count on you guys :-)
