Need Help Ford 600 Hydraulic
RoyLynn1960
03-10-2014 12:40:45
Hello I need help I have a Ford 600 that leaks the hydraulic fluid into the transmission then it comes out of the gear shift. I have been told it may be a seal or a hole in the line that runs through the transmission. I read that you can sleeve the line? Please help Thanks Roy in Texas
Kurt-NEPA
03-12-2014 16:59:46
 Re: Need Help Ford 600 Hydraulic in reply to RoyLynn1960, 03-10-2014 12:40:45
Wow! if the tube is in there without epoxy it can't possibly seal. If you have the tube out, you could clean everything really well, scuff up both tubes, then coat ID and OD with marine grade JB weld and put the tube back in.
See the current thread on the Ford forum for some info on this.
ZANE
03-10-2014 18:41:06
Both the bottom and top transmission shafts have seals at the back side that prevents the oils from mixing. My experiance has been that it is the seals.
It's according to how fast the oil gets into the transmission if it's the seals or the tube. Tube fast. Seals slow.
Zane
RoyLynn1960
03-10-2014 20:13:07
 Re: Need Help Ford 600 Hydraulic in reply to ZANE, 03-10-2014 18:41:06
Thanks for the info I just took the manifold off and it was sleeved I was able to remove it with very little effort when I took it off I noticed that the sleeve end looked like it was to one side and it looked like that oil could blow through it. I going to replace it and hope that fix it next stop will be the seals.
soundguy
03-11-2014 16:31:43
 Re: Need Help Ford 600 Hydraulic in reply to RoyLynn1960, 03-10-2014 20:13:07
sounds like a poorly implemented sleeve job.
perhaps no epoxy.. or was not cleaned first. wrong tube size..e tc..
find any epoxy coating?
RoyLynn1960
03-12-2014 16:41:18
 Re: Need Help Ford 600 Hydraulic in reply to soundguy, 03-11-2014 16:31:43
No epoxy when I clean the old tube out the old sleeve was 28.5 inches long I took the bottom plate off so when I insert the new sleeve will I see it on the other side. Do we just insert till it stops and then cut it off. Thanks.
soundguy
03-13-2014 07:14:26
 Re: Need Help Ford 600 Hydraulic in reply to RoyLynn1960, 03-12-2014 16:41:18
WOW.. no epoxy!
what an idiot that did the repair the first time. no wonder it didn't seal.
pullout.. clean up with solvent,a nd epoxy
Kurt-NEPA
03-10-2014 15:27:25
Yep, its a common problem with the hundred series tractors. Take a look a the recent thread on the Ford forum. It might help you get started.
Link
Dollar Bill
03-10-2014 13:19:55
Your symptoms come up frequently - Sounds like you have a leak in the pressure tube that runs through the transmission. Water gets into the transmission and pits the outside of the pressure tube and eventually develops a pinhole leak. As the hydraulic pump runs, it pushes oil into the transmission, filling it up until it runs out some place. Usually through the input shaft into the bell housing, or out around the shifter as you are seeing.
Here is a link that describes replacing the tube
Here is another thread
