BeaverIslander
I just received a new fuel line (A-9N9282A) for my 49' 8N to replace the rubber line and inline filter that was on it. Neither of the fittings on the new fuel line fit into the existing setup which was probably cobbled up (everything else has been) so did I get the wrong one? Coming off the shut off valve the new fitting is to small, maybe I'm missing an adapter for the lack of a better word. On the carb end the flared fitting does not go in far enough to allow the fitting to even begin screwing in so I'm not sure if it will fit but it appears that it should. If it is the correct one am I just missing some parts? Could someone tell me what I need to get for the shut off end, and what do I do about the carb end? Is it supposed to be filed down, is it missing something or did I simply get the wrong part.
1. shutoff valve end, 2. carb end, 3. to much flare?
<a href="http://smg.photobucket.com/user/beaverislander/media/IMAG1072_zps53800b25.jpg.html" target="_blank">
</a>
<a href="http://smg.photobucket.com/user/beaverislander/media/IMAG1076_zps5bfd9f41.jpg.html" target="_blank">
</a>
<a href="http://smg.photobucket.com/user/beaverislander/media/IMAG1080_zpsd07f84fa.jpg.html" target="_blank">
</a>
I could not find the answers in the manual, so I need to pester you guys once more as I have one shot at getting the right parts over here before a long weekend.
