heat gauge
DavidOwen
08-15-2013 16:21:23
did the 8N not have a heat gauge? Should I put one on?
NoNewParts
08-16-2013 04:05:20
 Re: heat gauge in reply to DavidOwen, 08-15-2013 16:21:23
I like gauges, the more, the better.
If you are keeping it and it's a worker, add one
When I get one that I am going to sell/trade
I keep a meat thermometer with me always.
I pop it in the neck when doing various tasks/loads
just to see the condition of the cooling system.
They'll fool ya sometimes. Working on an old AC,
stopped to mess with the carb needle/float, my hands told me
the engine was much too hot. Popped in the thermometer,
230 degrees....
It was running happily with no sign.
back to the shop.....
some enterprising inventor needs to make a radiator cap with a thermometer built in (sorta like some tractors that have one in the upper return)
36 coupe
08-17-2013 16:08:37
 Re: heat gauge in reply to NoNewParts, 08-16-2013 04:05:20
Its already been invented.Called a motometer.Model T and A FORDS HAD THEM.
NoNewParts
08-18-2013 05:06:01
 Re: heat gauge in reply to 36 coupe, 08-17-2013 16:08:37
Thanks coupe
don't mess with cars that old, so I googled it
cool
one of those fancy ones would have been perfect on the
Model A powered Ferguson tractor I posted pics of a few years ago!
Hobo,NC
08-15-2013 19:26:50
 Re: heat gauge in reply to TOM N MS, 08-15-2013 16:21:23
Ultradog MN said: (quoted from post at 04:09:12 08/16/13) They did not come with a temp gauge.
Some guys like them so add one either in the upper radiator hose or tap into the head.
I just use my sniff gauge.
An attentive operator can usually tell if his engine is getting hot just by the way his engine smells.
Nuttin like boiling coolant is it... I have yet been able to tell the difference from the smell if its 250 are 350 deg...
I guess you could also look at it this way if it cools down and runs again it may live to see another day if not call the family in.... Its the gamble those take that believe in myths my self I have a temp gauge....
Just a thought would you be satisfied if none of the gauges worked on you blue tractors are is this a N thang...
This post was edited by Hobo,NC at 19:28:52 08/15/13.
Ultradog MN
08-16-2013 05:11:44
 Re: heat gauge in reply to Hobo,NC, 08-15-2013 19:26:50
"would you be satisfied if none of the gauges worked on you blue tractors are is this a N thang... "
Well Hobo, if I must confess...
I stole everything off of my own tractor to get a couple of other ones sold.
There are only two wires on it - the positive and negative battery cables.
I have to charge the batery once in a while but it's one of those big 4DLTs so I get about 75 starts before I have to do it again.
But I am working on it :)
See my post on the Ford board (RickB).
I have the new style block so am going to go with a 3600 style tach drive and gauge cluster, 10SI Alt and be done with that Lucas stuff.
I did have a OP gauge on it for a while but Kenny stole that so I'm working on a wing and a prayer. And I keep my nose and ears well tuned.
PS,
Pay no attention to the lack of a nut and cover on the steering wheel. They're just on there to keep people from stealing it aren't they?
third party image
Bob Harvey
08-15-2013 18:48:57
An Option is available. No affiliation, just from a previous post. HTH
http://www.glowshiftdirect.com/38-mm-water-sender-attachment.aspx
DavidOwen
08-16-2013 03:34:19
 Re: heat gauge in reply to Bob Harvey, 08-15-2013 18:48:57
thanks everyone. I grew up on an 8N but didn't remember it didn't have a heat gauge. I think I will ad one. thank you.
Ultradog MN
08-15-2013 17:09:12
soundguy
08-15-2013 17:14:43
 Re: heat gauge in reply to Ultradog MN, 08-15-2013 17:09:12
ditto that. keeps the operator paying attention.
