so, near as I can tell, the ammeter from my ratty 1948 8N is intact. the needle bounces freely, stays centered on zero... when I remove the shunt/clamp (I'm assumign the clamp piece doubles as the current shunt, and has to be insulated from the back of the front panel?), I measure about 3 ohms across the meter movement, which sounds about right.
my tractor is wired very crudely, see
[u:5967a0f31f][b:5967a0f31f]http://freescruz.com/8nTractorWiring.pdf[/b:5967a0f31f][/u:5967a0f31f]
I am guessing I can just put the ammeter in series with the alternator, using suitably heavy wire? (existing wire that goes to teh alternator instead screwed onto one side of the ammeter, and a new wire from the other side to the alternator B+ ?)
