Still out of ideas.
RuintTX
07-13-2013 10:26:11
First - Thanks for all the replies!!!
Still won"t start -- All the ignition parts have been changed and I do have a good blue spark. Carb was leaking a little - gave it a rap in case of sticky float. Starting to worry about compression, but this was running when I shut it down. Carb is one year old (from this site) and it seems like the adjustment screws tightened up. 1/2 turn out on both -- will start there but I got a bad feeling. Seem to recall that 1 - 1 1/2 out on both screws is good starting point.
soundguy
07-13-2013 13:31:35
 Re: Still out of ideas. in reply to RuintTX, 07-13-2013 10:26:11
thumb test your valves..
GB in MT.
07-13-2013 11:16:45
Try these settings, and let me know if they work for starting/running.!!!
third party image
Gary :)
Retired Farmer
07-13-2013 11:10:59
Give it a shot of ether. If it fires on that, your carburetor is probably plugged up. Do a compression test then you will know if the valves are working.
old
07-13-2013 10:31:40
Main jet the one that is at an angle should be around 1-1/2 turn out. The smaller one up close to the top around 1 turn
