Ventilated or non-ventilated Blue Streak Points
kylemorley
05-21-2013 10:25:16
Many people have expressed a preference for Blue Streak points here. Are they referring to the ventilated or non-ventilated ones?
I have found non-ventilated Blue Streaks at $10 from several vendors, and haven't even been able to find a part # for the ventilated ones at all so I am starting to wonder if they even exist.
soundguy
05-21-2013 13:13:19
 Re: Ventilated or non-ventilated Blue Streak Points in reply to kylemorley, 05-21-2013 10:25:16
sidemount vented points are napa cs753
Dean
05-21-2013 11:58:00
Once available.
Perhaps no longer.
Dean
36 coupe
05-24-2013 05:05:38
 Re: Ventilated or non-ventilated Blue Streak Points in reply to Dean, 05-21-2013 11:58:00
Just took a set out of a front mount.Couldnt adjust the gap wide enough.Looked like a plastic rub block.
soundguy
05-21-2013 13:12:21
at least for sidemount they are.
regualr side mount from echlin are cs 749
the vented are cs753
I double checked napa's site and they still list them.
Dean
05-21-2013 16:43:45
 Re: Ventilated or non-ventilated Blue Streak Points in reply to soundguy, 05-21-2013 13:12:21
The original poster did specifically state "Blue Streak," to which my reply refers.
That said, I've used both Std Ign and Echlin and been pleased with both.
Dean
soundguy
05-21-2013 17:11:54
 Re: Ventilated or non-ventilated Blue Streak Points in reply to Dean, 05-21-2013 16:43:45
i've used standard/blue and BW and echlin.. and honestly. among their premium line. I can tell no operational difference. I think all are quality points.
I was thinking the poster was simply asking about the HD vented poitns in general and using blue strak as a possibility as they are mentioned alot.
my mistake.
soundguy
05-21-2013 10:31:22
i've found sidemount pierced points from napa.
it's been a few years since I've bought any .. probably 09 or so. .. nope.. sept 2010 .. when i got my 950.....
kylemorley
05-22-2013 06:23:51
 Re: Ventilated or non-ventilated Blue Streak Points in reply to soundguy, 05-21-2013 10:31:22
I should have mentioned, I am looking for front mount points.
I still would be interested in hearing any thoughts on the ventilated or non-ventilated question.
This post was edited by kylemorley at 06:34:12 05/22/13.
soundguy
05-22-2013 06:33:08
 Re: Ventilated or non-ventilated Blue Streak Points in reply to kylemorley, 05-22-2013 06:23:51
it does nelp to narrow it down.
can't help you there. last set i bought was in 04... still running them. and I'm pretty sure they were just cs35 echlin points. don't recall them being peirced either...
