Honey and cinnamon mixture
TOM N MS
03-29-2013 21:21:42
Any good/bad opinions? Experiences?
TOM N MS
03-30-2013 18:01:29
 Re: Honey and cinnamon mixture in reply to TOM N MS, 03-29-2013 21:21:42
Thanks everyone--Most likely stick with apple cider vinegar and honey..Don't like the cinnamon.
Den N Ms
03-31-2013 18:17:11
 Re: Honey and cinnamon mixture in reply to TOM N MS, 03-30-2013 18:01:29
Tom,It really helps me out ,have been taking it twice daily for about 3 years.Hope it helps you too,but you need to take it religiously.
Den N Ms
03-30-2013 09:45:12
Tom, Also Honey and Vinegar works to.
TOM N MS
03-30-2013 10:01:04
 Re: Honey and cinnamon mixture in reply to Den N Ms, 03-30-2013 09:45:12
Had forgotten about that--yrs ago my Mother heard about a concoction called Jogging in a jug-it had vinegar, apple cider, maybe orange juice, cranberry juice, and such in it..I remember holding my nose and downing an ounce a few times.....now I know to try vinegar and honey again seems that cinnamon will not mix if u try to pre-mix it..it is yuckier than the vinegar.
R Geiger
03-30-2013 09:37:05
 Re: Honey and cinnamon mixture in reply to heybusdriver, 03-29-2013 21:21:42
found this: Link
TOM N MS
03-30-2013 10:06:15
 Re: Honey and cinnamon mixture in reply to R Geiger, 03-30-2013 09:37:05
Good info-had seen some of the same info but I believe that is the best I"ve seen. If it will do half what they claim, it is great and everybody ought to take it..
teddy52food
03-30-2013 07:38:32
I use it every morning. Keeps my hands from hurting from the arthritus.
TOM N MS
03-30-2013 08:55:07
 Re: Honey and cinnamon mixture in reply to teddy52food, 03-30-2013 07:38:32
How do you mix it and how much do u take each time? Had heard it was good for arthritis but didn"t know if it was really true.. Thanks
teddy52food
03-30-2013 12:14:31
 Re: Honey and cinnamon mixture in reply to TOM N MS, 03-30-2013 08:55:07
I use a spoonfull in a cup of warm water. My wife gets cinnamon capsuls for me & I take 2 each morning before breakfast With the honey-water.
TOM N MS
03-30-2013 18:52:07
 Re: Honey and cinnamon mixture in reply to teddy52food, 03-30-2013 12:14:31
Thanks-did not know about the capsules.
hd6gtom
03-30-2013 06:22:02
What do you intend to use it for? Both honey and cin have good properties, come back
TOM N MS
03-30-2013 07:04:42
 Re: Honey and cinnamon mixture in reply to hd6gtom, 03-30-2013 06:22:02
I think everyone has known forever that honey is good for u but I had never heard about cinnamon...I really expect nothing in particular from it. Just saw some hype about it lately and am curious if anyone has taken it and seen miraculous results..
36 coupe
03-30-2013 14:48:20
 Re: Honey and cinnamon mixture in reply to TOM N MS, 03-30-2013 07:04:42
Honey keeps me from sneezing.The cinnamon will reduce high blood pressure.Friends doc told him to use cinnamon to reduce blood pressure.
TOM N MS
03-30-2013 15:52:26
 Re: Honey and cinnamon mixture in reply to 36 coupe, 03-30-2013 14:48:20
Thanks-yes, blood pressure control is one of the things mentioned frequently, so I guess there might be something to it..
R Geiger
03-30-2013 08:04:49
Works better when mixed with good blended whiskey!
Mad farmer
03-30-2013 08:08:55
 Re: Honey and cinnamon mixture in reply to R Geiger, 03-30-2013 08:04:49
Or for brewing hard cider!!!
Dell (WA)
03-30-2013 00:59:11
Tom..... ...dissolved in warm lemonade is good gargle fer sore throat. Dissolved in warm orange juice is good fer quick nitetime beddy-buye sleep aide. ..... ...yawn, Dell
TOM N MS
03-30-2013 04:31:53
 Re: Honey and cinnamon mixture in reply to Dell (WA), 03-30-2013 00:59:11
I needed a pint of the OJ mix last night---did not sleep worth a flip.
Dave in Wyoming
03-29-2013 21:55:23
I have used it for heartburn, and a sour stomach, and it worked pretty good. They say it"s good for all kinds of things for a person, but I doubt it will fix a tractor. LOL
Dave
TOM N MS
03-30-2013 04:25:10
 Re: Honey and cinnamon mixture in reply to Dave in Wyoming, 03-29-2013 21:55:23
O.K.thanks Dave-will remove poultice from the rear axle....sure thought it was getting a little better-must have been my imagination.
Bill Rowles
03-29-2013 21:47:11
won't fix a rod knock or leaking valves but may help piston rings sometimes..... careful where you put it.
TOM N MS
03-30-2013 04:35:56
 Re: Honey and cinnamon mixture in reply to Bill Rowles, 03-29-2013 21:47:11
Good point-and probably good for radiator leak-mix some with grated nutmeg. BTW nutmeg does work as temporary small leak stopper.
36 coupe
03-30-2013 14:52:26
 Re: Honey and cinnamon mixture in reply to TOM N MS, 03-30-2013 04:35:56
A piece of ginger root in the rear end will make an old horse prance like a yearling colt.
TOM N MS
03-30-2013 17:58:44
 Re: Honey and cinnamon mixture in reply to 36 coupe, 03-30-2013 14:52:26
I would think so..
old
03-29-2013 21:37:16
Not sure what your asking. I have been around Honey and bees since I was say around 8 or so
TOM N MS
03-30-2013 04:29:08
 Re: Honey and cinnamon mixture in reply to old, 03-29-2013 21:37:16
Do a quick search-it is suppose to cure many ailments-even suppose to help your hearing-wife wants me to find it in pre-mixed gallons.
old
03-30-2013 21:42:19
 Re: Honey and cinnamon mixture in reply to TOM N MS, 03-30-2013 04:29:08
Not that I can or would do it but would you believe getting a bee sting a day can help with many problems. Arthritis for one but me I'll not do it but then doing it can send me to the hospital
TOM N MS
03-31-2013 04:34:33
 Re: Honey and cinnamon mixture in reply to old, 03-30-2013 21:42:19
I know what u mean-my Dad had a bad experience with bee stings many yrs ago..As for me I think I had rather be snake bit..
