2n front spindle tapered pins
2nthom
New User
I read about a guy named OLDHOKIE who can make tapered pins for my 2n front spindles. I want to get ahold of him and order some. Thanks to who ever replies with his info.
2nthom
(quoted from post at 06:46:27 09/18/12) 2N'S did not use the tapered pin.They used a bolt and nut.You must have 9n spindles????? don b
Serial # 100058 indicates a 2n. Either way, it has tapered pins. Thanks for the reply though.
Could you check some items on your tractor for me? Does your front axle pivot pin extend front to the back of the grille hand crank hole? If standing in front of the tractor is there a 1/8" hole facing front just to the left of the grille in the LH side panel that goes up and down beside the radiator?
(quoted from post at 17:33:04 09/18/12) Could you check some items on your tractor for me? Does your front axle pivot pin extend front to the back of the grille hand crank hole? If standing in front of the tractor is there a 1/8" hole facing front just to the left of the grille in the LH side panel that goes up and down beside the radiator?
Yes, there is a 1/8" hole to the left of the grill. Also, the axel pivot pin is completely round, no flange.
