Hi folks,
Is it possible to use a jumper to ground from the solenoid (or other component) to activate the starter and turn-over the engine? This is a 51' 8n 6v side mount. Wondering what best way to do this is.
I want to bypass the push button switch and the key ignition switch if possible to troubleshoot an intermittent starting issue I've been having.
TIA
TIA
