2N brake installation
tracman
I am having trouble putting the brake shoes back in the brake drum. I have backed the adjustment off as far as it would go. Does the shoes and backing plate just drop in or is it a snugg fit? Any thoughts would be helpful. tracman
I had the same problem trying to get the brakes back in my drum. Turns out the adjuster was just gummed up an was not backed out all the way. I worked the adjuster back and forth with plenty of solvent and muscle and eventually it backed out enough to get the brakes back in the drum.
TB in MN
(quoted from post at 18:53:48 10/17/11) I had the same problem trying to get the brakes back in my drum. Turns out the adjuster was just gummed up an was not backed out all the way. I worked the adjuster back and forth with plenty of solvent and muscle and eventually it backed out enough to get the brakes back in the drum.
TB in MN
Thanks. I will keep working it a bit more and maybe loosen it up enough. I also found that there is a ridge on the brake drum and it is rusty. I will polish that up as well.
tracman
