volt meter wiring
Scott Massey
New User
I have converted to 12 volt and wired this as in the ford 8n side distributor 1950 to 1952 wiring diagram by K. LaRue. What wiring needs to be changed per this diagram if any to properly wire in a volt meter instead of a amp meter. I will be wiring in the delco 10si 3 wire alternator also. I have searched this site and only read about wiring the one wire alternator. Thank any help would be appreciated.
<img src = "http://i167.photobucket.com/albums/u125/27Grainfield/N%20Ford/12VwiringWithVoltmeter.jpg">
Scott......Bob posted an excellent drawing for voltmeter installation. Its only "on" when the ignition switch is ON, just like you'd want it. ......Dell
