My N had troubles earlier with alt, bat, dist and coil. All of which have been resolved. Turns out the alt was defective and threw out too much juice and caused the other items to fail. Well anyhow, when I was in the middle of all those issue"s I searched high and low for a wiring diagram that matched or came close to what I have. I haven"t seen it yet. And yes I looked here and justN"s, hobo"s and Smith"s and other places. So I thought I"d use what little artistic ability I"ve got to show what I have to see what I can learn from you all about it.
Disclaimer: The tractor was converted by a PO and when I got it it did not have a Ballast resister or terminal block. Also I left the lights out of this drawing. Since the bulbs I put in are 12v they can be wired up a couple of different ways.
Right now the tractor has setup "A" on it. But I"m wondering if setup "B" would be better. Thanks for any input.
