I bought a 1945 2n ford tractor. This is my first experience with a 12 volt conversion. The Tractor was already somewhat converted, but was still using positive ground. The tractor ran ok but wasn't charging battery. I have since rewired tractor with diagram found on this site for early 8n ford tractor front distributor (attached below). For some reason when I attach battery all lights work fine but when I push starter button system grounds out. I have narrowed it down to starter itself is grounded. By that I mean terminal post at starter is a ground and I dont know why. Hoping someone can shed some light because I am running out of ideas.......Thanks, Jim
http://home.earthlink.net/~8ntractor/12volt.html
