Another question re the 2N lift. When I pulled the lift cover off today, I noticed that I could move the control spring around, but I didn't notice this until after everything was disconnected. Compare the position in these two photos:
I was able to "bend" the spring off to the side (note the difference near the base of the spring). Is this normal when everything is disconnected, or does it indicate I need to adjust the spring tension? Thanks in advance!
