As I mentioned in this thread (link), in the process of replacing the manifold on "my" 2N, I broke the vertical rod that goes from the throttle control rod that runs along the top of the motor to the governor linkage. I got a replacement, but found that although I could attach it, the throttle would barely move the motor off idle. I concluded that either my replacement rod was too short (P/N 9N 9815 vs 9N 9815B), or that the governor needed rebuilding due to slop in the linkage.
Phew! So much for the background. Here's my question: on a '44 2N, what's the normal shape of the throttle control rod that runs along the top of the engine? On mine, the arm that comes off of it makes a 90 degree turn toward the front of the tractor about half way along its length (I wish I'd taken a picture). This also means that the vertical rod has to be bent a little bit to clear the manifold. So I'm wondering if that upper arm is really supposed to be completely straight. If it were, the vertical rod wouldn't need to be bent, and it would also provide greater travel.
If it is supposed to be straight, how can I straighten it without breaking it? Would the heat from a propane torch be enough to "soften" it?
Thanks in advance!
Thanks in advance!
