[b:fbe322f954][i:fbe322f954]
WW;.....you ask:How were you able to determine where the hangup was? Could you feel it with your hands on the right wheel,
Yep....while the wife slowly turned the steering wheel, I had both hands, front and back of the tire, lightly.
I had done the lft. side first, and it felt nice and smooth turning. But then I did the right side, and felt a series of small jerking movements, after she had turned the wheel about 1/3 of a turn.
The reason I went directly to the spindle area first was, that they looked like they had NOT been greased for some time.(the zerks were pretty crusty)!! I threw them away, and after workin' on it, installed new zerks.
Most of the PB BLASTER has since drained out, and I use wheel bearing grease in the spindles now. Seems to work better than reg. Multi-grade grease.
Your prob., could be other places than what mine was, altho this was the easiest place to start. It just so happened I lucked out going there first.
BTW: I always use the front bottom of the oil pan to jack up the axle, off the ground. I use a roll around 2000lb., car jack, with a 2x6 board for a top plate. Jacking on the axle support, is not very sturdy. JMO
Where in San Diego co. do ya live???? My son is still living in our old place, in Spring valley> He bought that from the wife and I, after my Military retirement.
Gary
[/i:fbe322f954][/b:fbe322f954]
