First off, I'll admit that after you read the below, you'll likely think I'm jumping the gun on asking this question. Feel free to blow me off and I'll come back later, but the tractor in question lives 40 miles away, and I like to go armed when I go out there.
The 2N I'm looking after starts right up when it's cold, but is really hard to start when it's hot (or warm), i.e., after use. It'll usually start eventually, after some playing around with throttle and choke. Why it should need choke when hot I have no idea, but without choke it never threatens to start.
The most obvious known problem is that it has a leak in the exhaust manifold at the rear, just before it turns down to the exhaust pipe flange. This area has been (badly) welded by previous owner and is leaking again. I've got a new manifold on order. So, I'm guessing we've got less than normal back pressure, but I won't know what else might be going on in that area until I get the manifold off.
I also have not yet done an ignition tune-up (it's next on the list) or even changed fluids on this recently-acquired tractor.
Could I be getting vapor lock? Or is it the manifold an obvious problem that I'm just failing to understand? Or should I just shut up until I've done the basics?
Thanks in advance for your help.
