Ford 9n light wiring diagram
H White
New User
Does anyone have a wiring diagram or know where i can find a wiring diagram for the lights on a Ford 9n? Thanks for the reply.
(quoted from post at 21:58:07 11/06/08) Does anyone have a wiring diagram or know where i can find a wiring diagram for the lights on a Ford 9n? Thanks for the reply.
Sean's diagram is better because the lights don't go thru the ignition switch.
That is kind of a personal decision.
But trying to look at that yellow wire makes my eyes and my head hurt.
(quoted from post at 21:10:44 11/06/08)
[b:8ffb777ab7]JMORS's diagram...And you are right the yellow is hard on the eye's[/b:8ffb777ab7]
Hickie........the 9N/2N (both) have a 2-terminal roundcan cut-out relay at the bottom of the battery sheetmetal tray, just above the 2-terminal roundcan starter switch. go look. Remember you MUST "polarize" yer cut-out relay. Iff'n you need instructions on polarization, ask. .......Dell
(quoted from post at 22:07:30 11/06/08)
[b:944ff9f337]JMORS's diagram...And you are right the yellow is hard on the eye's[/b:944ff9f337]
OK, fellers! I didn't pick the wire colors........Henry did!
Pop a "liquid pain killer". :lol:
Especially for Dunk & Sean:
