(quoted from post at 14:23:22 11/04/08) JMOR... Thanks for the input. When I had the tractor running on Sunday, I noticed when looking into the sediment bowl that small bubbles were appearing at the top, as if they were getting sucked in. I have had the entire sediment bowl assembly off and cleaned it, however there was not much dirt there. I guess I'm not sure where the tank vent is to check if that is clogged. I'll have to check my shop manual. Could my tractor be starving for fuel when its running that it is trying to suck fuel faster through the gas line/sediment bowl? This could explain why it runs rough at times, that is until I open up the throttle or pull the choke out for a split second. Or is fuel strickly gravity fed into the carb? What would happen if I open the main needle valve way open...currently its at about 2 full turns from seated. Sorry for all the questions.
ANSWER: Hard to check that vent due to location and design, but simply loosening the gas tank cap will produce a 'for sure' temporary vent. Listen for sucking air sound as you open it and if open while running, does it make an improvement?
ANSWER: If it needs more fuel that it can get thru sediment bowl/line, then it means something along the flow path is clogged or the vent clogged.
ANSWER: Probably enrich the air/fuel mixture. "Probably", is because you could already be at maximum rich condition. In these carbs that Main Power Adjust needle is directly in series with the MAIN JET, therefore, which ever of the two is the smaller opening, determines the mixture.
COMMENT: If choking improves condition, that generally means it was too lean and the choke richened it a bit. Sometimes this can mask a weak ignition. With fuel running out bottom of carb, it is more likely too rich. Does it produce a sooty black smoke (too rich)? The needle/float assembly is supposed to shut off the flow into the carb when the fuel level is about 1/4 inch below the top/bottom carb split gasket. If this is as it should be, then fuel should not be running out bottom of carb , with the exception of excessive choke application at start up.
Needle seat assembly: The seat may not be sealing properly to carb body due to gasket or simply not tight enough. The needle to seat seal may not be good or have a tiny piece of trash in it.
MYSELF: I would try to stop the 'fuel leaking out of bottom of carb' before worrying about how it runs. Fix that & it will like start to run just fine.
