Something loose in oil pan
doodle
05-19-2001 09:01:08
Ford 8N 93826 Dropped the oil last night, was wiping around and putting plug back in when I heard and felt something move. Looked in and found a, what I will call, draw tube from the oil pump laying in the bottom of the pan. I assume the pan needs pulled and this re-attached. ? is Can a lamen do this or do I need a pro? How difficult is it to drop the pan. Looks like it could get hairy towards the front. Thanks in Illinois.
Old George
05-19-2001 23:21:14
 Re: Something loose in oil pan in reply to doodle, 05-19-2001 09:01:08
third party image
doodle, are you sure you did not use some of Dave#1's pistons. Cheap stuff, always falling apart and tend to leave aluminum tabs in everything. I think they are made in china and that could be what is rattling around in your pan.
Hope this helps:-)
doodle
05-20-2001 05:19:16
 Re: Re: Something loose in oil pan in reply to Old George, 05-19-2001 23:21:14
Cute
bj/8N/mt
05-19-2001 10:27:12
what he [Claus] said
also make sure you have the screen on top of the drain plug in place. That screen is what supports the end of the pick up tube and I would bet a beer it is missing or the tube couldn't have come adrift as you report. You also need to solder or otherwise attach the pickup to the pump so it can't suck air. This would also be a good time to check the pump itself for wear.
Your mileage may vary
doodle
05-19-2001 18:16:49
 Re: Re: Something loose in oil pan in reply to bj/8N/mt, 05-19-2001 10:27:12
Screen was there on oil plug just like it was supposed to be. Thanks for your help.
p.s. I drink Bud Light....ha ha
bj/8N/mt
05-20-2001 06:02:22
 Re: Re: Re: Something loose in oil pan in reply to doodle, 05-19-2001 18:16:49
A donation has been made to Dave #1 in your name
Greg
05-19-2001 09:20:06
Howdy doodle,(-;
If this is indeed the oil pump pickup tube you have discovered, you have trouble. Is it about 1/2" in dia. and have a large can/shield attached to one end? If so, you will have to get to the pump and the pan on these tractors is cast and part of the frame structure. If you are mechanically inclined and have some time and the tools and an F04 manual you can tackle it. I would recommend buying the manual, (you should have one anyway) looking the job over, and then decide your course of action. IMHO
Claus
05-19-2001 09:12:07
Ouch....Ensure that the tractor is well supported under the transmission, since the oil pan is part of the support structure, tractor frame. I prefer to use 2 X 12s about 2' long stacked up. block rear wheels. The front axle support has to be removed etc... Get yourself a IT-04 Manual. The pick-up tube is brazed/silver soldered into the pump housing... Do not run the engine...
Good Luck
Claus
doodle
05-19-2001 12:37:55
 Re: Re: Something loose in oil pan in reply to Claus, 05-19-2001 09:12:07
Thanks for advise. Is the IT-04 or FO-4 manual same as service manual? Can not find or is not that specific in "tractor manuals" section of web site. Thanks for help!!
Claus
05-19-2001 13:00:52
 Re: Re: Re: Something loose in oil pan in reply to doodle, 05-19-2001 12:37:55
Actually, it is I&T FO-4...If you click on manual on the Hypertext above the red line...You will find it..
Happy Motoring
Claus
Mountainman
05-19-2001 13:28:04
 Re: Re: Re: Re: Something loose in oil pan in reply to Claus, 05-19-2001 13:00:52
Claus,
while there are service manuals listed, there are none that are listed as FO-4. And the number of pages is not the same as either FO-4 manual I have.
Perhaps that is why so many folks are confused by the manuals listed. I don't know what manual the FO-S is.
FYI
Mountainman (CA)
doodle
05-19-2001 18:18:56
 Re: Re: Re: Re: Re: Re: Something loose in oil pan in reply to Claus, 05-19-2001 14:21:07
Thanks for the "try this" Manuals are on there way!!! Great job.
