Order Ford 8N Parts Online
Re 8N HY. OIL TUBE
LEANDER WILLIE
08-08-2005 08:00:16
Zane, could you tell me how to change out the oil tube that feeds to the top plate, mine has a hole in it about an inch up from the bottom, I can stick the big end of a sewing needle in that hole.I have the top plate and the pump out. The hole is looking toward the inside, looks like it might could be welded. I think I'd change it out if I knew how. Do you know where I can find one,are do you have one? Thanks . Leander.
