Order Ford 8N Parts Online
8n piston ID
bruddies pop
12-27-2004 15:48:38
I am overhauling an 8n. The piston has a slight dome top and 4 rings. At the CNH dealer today and they said all ford pistons are 3 ring. The piston has a casting no. A3113 on it does anyone know if its a TISCO or a M&W.
Dell (WA)
12-27-2004 16:03:33
 Re: 8n piston ID in reply to bruddies pop, 12-27-2004 15:48:38
Bruddies Pop..... ...the early N-Engine pistons were 4-ring; 2-compression and 2-oil rings. Theory was that 2nd oil ring would reduced oil consumption. Well yeah, it controlled so much oil that the cylinders wore out too fast.
Modern N-Pistons are 3-ring, with a very improved 3-piece oil control ring. 3-rings also have less friction and therefore are more efficent.
You can still order 4-ring pistons and 4-ring re-ring sets. But iff'n yer doing a full engine overhaul with new sleeves and pistons, gitt the 3-ringers. Tell your wet-behind-the-ears CNH parts person to read his parts books better..... ....Dell
