Linebach Post hole digger fit?
Terry Alexander
03-05-2001 07:15:45
I purchased a Linebach 7200 post hole digger. I have the PHD here and my 8N is 200 miles away. The specs on the PHD says that the output shaft is 2". Will this fit my 8N PTO or will I need to go to Ford NH for "something". If so....specifically what "something" will I need?
TIA
Terry
Paul - Pine Island MN
03-05-2001 17:08:59
 Re: Linebach Post hole digger fit? in reply to Terry Alexander, 03-05-2001 07:15:45
The key word is output - the input is driven by the pto and is 1 3/8 standard 540 pto on mine, the output is where you bolt on the auger.
Larry 8N75381
03-05-2001 08:50:29
I'd bet that they mean the shaft that the auger is attached to. That is about the size of mine - can't look since, like you, mine is 60 miles away.
Forgot to add..
03-05-2001 09:00:20
 Re: Re: Linebach Post hole digger fit? in reply to Larry 8N75381, 03-05-2001 08:50:29
You might like to see how I store my PHD.
There are two pictures of removing it from the tractor and one of it hanging in the barn.
eNjoy!
Larry
bj/8N/mt
03-05-2001 07:29:53
not familiar with that auger
there are two possibilities for PTO shaft diameter on 8Ns
Henry built it with a 1 1/8 splined shaft
Lots of 8ns have been converted over the years to 1 3/8 inch which is green tractor standard
If your auger has a two inch shaft doubt it will fit a catagory one three point which is what your 8N is
In any event I would measure before I hung out the plastic
