Order Ford 8N Parts Online
SERIAL NUMBER 8N
CLAYTON BLACKER
03-04-2001 14:06:13
HELLO FORD PEOPLE: my 8n serial number on left side of block is not all readable, wonder if anyone could tell me if there is any place else to look to get a number to identify the year. it has side mount distributor so must be 290271 or above.
thanks ahead clayton
Phil@TX
03-04-2001 14:29:02
 Re: SERIAL NUMBER 8N in reply to CLAYTON BLACKERT, 03-04-2001 14:06:13
It might be a little earlyer than that. My 8n is ser# 8n284329 and it has the side distributor. One place you can look that might help pin point the year model is the aluminum plate under the pump housing it should have the date it was cast.
Tyler (MD)
03-04-2001 14:23:57
Look at the axle trumpets closely. There should be some numbers on them that will associate a date with your tractor (if they're the originals).
Click the link below for additional info.
