Size for front hub bolts?
Dan
06-18-2004 04:51:48
I am looking at a axle spindle rethreading set as my front lug bolts that hold the tire to the hub have worn down. I looked in the Master Parts book, but it does not give the bolt and thread size on the front wheels as they do for the back. Will a 13/16" X 20 or a 3/4" X 20 work for the front hub bolts as a die?
TIA,
Dan
Dan
06-18-2004 08:06:37
 Re: Size for front hub bolts? in reply to Dan, 06-18-2004 04:51:48
Thanks all. I will replace the studs when the wear smooth on the top. I am just trying to clean up the threads so I don't have to bust a &%$ when I have to remove or replace a lug nut by hand as I do presently.
Dan
OH Boy
06-18-2004 07:49:11
Wouldn't you be better off just replacing the lug studs, I thought I saw someone here say they could be pounded out and replaced. ??
jimmac (WA)
06-18-2004 06:52:12
Dan, If Im not mistaken my MPC lists those as 1/2 x 20. HTH Jim
Dell (WA)
06-18-2004 07:48:20
 Re: Re: Size for front hub bolts? in reply to jimmac (WA), 06-18-2004 06:52:12
Dan..... ..this is to confirm Jims post..... ..in the N-Ford MPC: Replaceable Front wheel hub lugbolt, p/n 78-1107, 1/2-20 x 1.26", with shoulder, flat sided head..... ..Dell
don b
06-18-2004 10:26:33
 Re: Re: Re: Size for front hub bolts? in reply to Dell (WA), 06-18-2004 07:48:20
That is correct and are available for 2.00 each. don
gahorn
06-18-2004 15:47:44
 Re: Re: Re: Re: Size for front hub bolts? in reply to don b, 06-18-2004 10:26:33
I replaced the lugbolts on my front hubs with a 20 ton hydraulic press and it took about 12 tons of pressure to push 'em out. I was just about to chicken out for fear of breaking something, then They shot out with a "bang" that would scare a deaf mule. Wear safety glasses. And don't just go down to the autoparts store and try to find automotive lugbolts....use the genuine part. Automotive types will crack that cast hub because the auto types have anti-rotational splines and they cannot be properly fitted without stressing the hub. Cast hubs are brittle and a little crack will occur at each lugbolt hole if you don't use the correct Ford part. (Don't ask.)
