Carburetor trouble
john_t
01-28-2001 18:58:10
So I'm rebuilding the carburetor on my 8n.....
and I can't get the main jet out. The one I'm talking about is down past the main nozzle.
Well,to make a long story short,I destroyed the jet. Hopefully I didn't destroy the carburetor casting. Here's my idea for a fix: remove the 8-32x5/64 plug from the bottom of the bowl and run a 8-32 tap into the hole thereby renewing the threads for a new jet. (I think the jet has 8-32 threads) Any thoughts/ideas?
Rod Mi
01-28-2001 20:59:13
 Re: carburetor trouble in reply to john_t, 01-28-2001 18:58:10
Have you tried soaking to carb in penetrating oil for a week or sow then drill out jet big enough to drive a ezout in the jet and remove? I don't normally suggest using ezouts but in brass or bronze they sum times work and I'm not familiar with your carb this worked on my 4000. your suggestion sounds good to but I would do my suggestion first then make the hole bigger if don't work then do your idea. that way you have two chances to mess it up good luck
Rod Mi
01-28-2001 20:58:36
Have you tried soaking to carb in penetrating oil for a week or sow then drill out jet big enough to drive a ezout in the jet and remove? I don't normally suggest using ezouts but in brass or bronze they sum times work and I'm not familiar with your carb this worked on my 4000. your suggestion sounds good to but I would do my suggestion first then make the hole bigger if don't work then do your idea. that way you have two chances to mass it up good luck
JimNC
01-28-2001 19:14:52
This link was posted yesterday. It may help.
john_t
01-28-2001 19:19:02
 Re: Re: carburetor trouble in reply to JimNC, 01-28-2001 19:14:52
funny thing....thats the article i was using to guide me... I still messed it up. LOL!!!
