Transmission noise
jim
08-08-2003 06:19:38
The transmission on my 1940 9n S/N 9N28245 makes a clattering noise sound when the tractor is in netural and rolling either backwards or foreward the shifter stick also vibrates back and forth when this happens.Feels like the gears are hitting,is this a normal? or is it a big headache.And also is it an easy fix?I am a first time tractor owner ank know very little about this kind of thing.please help!
Jim
pete--NY
08-08-2003 17:21:22
 Re: Transmission noise in reply to jim, 08-08-2003 06:19:38
I bought a salvage cover for my '40 9n from Wengers of Myerstown (PA) for $47.OO. May be cheaper than welding. Be sure it's alum. and that it has the dip stick hole if you want to retain it's originality. Pete--NY
Scott
08-08-2003 16:14:35
The shifter cover is worn or broken under the rubber boot where the anti rotator pin fits through the shifter, it is cast alluminum so a high tech welder is required to repair, the pin, cover gasket and boot are still available if needed, be very careful when removing the steering column and dash as the dash is very brittle.
