picture question
ED-IL
08-07-2003 10:56:35
third party image
saw this picture on e-bay and had a question - why is there a copper line tapped into the air pipe leading to the carb?
Matt Doyle
08-09-2003 18:38:12
 Re: picture question in reply to ED-IL, 08-07-2003 10:56:35
Anybody else notice the nonoriginal seat? Rock Island Plow Co.
Dave_NC
08-07-2003 20:06:24
California Emissions Model
koontz
08-07-2003 20:04:45
wolf whistle, hadone on my 54 ford car, worked on the intake vac.
here is what the seller s
08-07-2003 18:23:49
he said...
"Hello, Thats the factory vacuum advance line."
...what does that mean?
D. R. White MN
08-07-2003 18:58:33
 Re: Re: picture question in reply to here is what the seller s, 08-07-2003 18:23:49
I think what some one may have done is taken a dist. from a 1940 to 1948 FORD flat head V8 they had a front mount dist. the castings looked the same but for the vacuum advance pot, and then some how made it work on the N series tractor. The V8 dist. has dual points in it and the cap has 8 nipples on it but the tractors 4 place will fit on the casting but then there is the rotor thing to work out. I can't remember what that looked like on the V8. Just a guess. Dave.
Jeb2n
08-07-2003 14:55:13
That tractor is interesting because of the Steel wheels. The fact that it has steel wheels leads you to beleive it's a wartime 2n, however, he says that it's a 1941 which would make it a 9N. Combining that with the fact that there is a generator, no permanently attatched hand crank (as the war models had), nor the hole for the choke in the grill, it leads me to beleive that this is a 9N that somebody just put steel wheels on for kicks. That's odd because most people would not spend the money to get steel wheels unless they wanted to go back to original (certainly not for the comfortable ride!) and the 9N just doesn't fit. Sorry about being OT, but i'm just thinking out loud.
Joe Ferguson
08-07-2003 11:47:59
Hi Ed
Tube seems to be connected to/or/near the oil
filler tube.
May be to aspirate cranckcase fumes
home-made cranckcase ventilation system ???
Who knows
Joe Ferguson
Tom (MI)
08-07-2003 11:56:17
 Re: Re: picture question in reply to Joe Ferguson, 08-07-2003 11:47:59
Could there possibly have been some sort of ether deal rigged up, to help on cold mornings? I've driven a few Peterbilts that had an ether button on the dash.
Brian-2N
08-07-2003 11:10:46
M.I.C.K.E.Y M.O.U.S.E.
Looks like the Walt Disney approach to some kind of "improvement".
Salmoneye
08-07-2003 11:09:34
Dunno...
But one of the other pics shows where the line comes across the head and down behind the radiator hose...
Weird...
third party image
souNdguy
08-07-2003 11:23:31
 Re: Re: picture question in reply to Salmoneye, 08-07-2003 11:09:34
Any chance of there being a small pulley ran smog pump or other type of air pump down there outside of the picture... kind of lie a poormans super charger.... that is weird... someone email the guy and ask what it is....
Soundguy
souNdguy
08-07-2003 11:03:22
2 GUESSES come to mind... either something is being injected into the system ( nitrous?!! naaaa... or even extra airflow from a low volume pump? )
Or they might be using manifold vacume for something... don't know past that.
Soundguy
George Willer
08-07-2003 17:02:26
 Re: Re: picture question in reply to souNdguy, 08-07-2003 11:03:22
souNdguy,
Maybe someone tried to copy the same crankcase ventilation system as used on your new Cub? It depends where the tube leads. A line runs from the intake tube to the crankcase of the Cub. The intake tube has a slight vacuum, due to the resistance of the air cleaner. It looks like a good idea.
George Willer
