Lift- leaks down
Travis 'N Texas
06-21-2003 07:37:04
I know this has been addressed many times but I'm not finding what I'm looking for. First my 8N lift quit working unless I put it in Draft control & held the lever down hard. On Zane's advice, I used his Zane's Adjustment Jig Thing, & replaced the cam follower pin. (Being somewhat mechanically challenged I was scared to do this myself but Zane's jig & instructions led me right through it & fixed that problem.) The lift now lifts as it it should but leaks down in 10 minutes or so with only a 5ft back blade on it. I watched the fluid & there is some turbulence but no "whirl pool". Whats my next project?
Thanks, Travis
souNdguy
06-21-2003 21:50:47
 Re: Lift- leaks down in reply to Travis 'N Texas, 06-21-2003 07:37:04
10 minutes? Brag, brag, brag...
Mine starts to slowly drop just a few seconds after my foot touches the clutch...
Soundguy
Rob
06-21-2003 07:48:58
I hear you can put your finger over the end of the spark-plug like relief valve there on the bottom in the back and if it's leaking it will push your finger away. That would do it.
Go to the pawn shop and buy an 11/16" combo wrench, should cost you all of a dollar or two, and bend it 90 degrees so you can get it on the valve from the left-hand inspection hole. Spin off the valve making sure you get it all out and put in another one.
You may have other problems though. Check the relief valve first.
