Is a Class I hitch always a Class I?
JD in SC
06-13-2003 11:15:29
In my search for a small utility tractor to supplement my 8N, I find that most of these small tractors (Kubota, JD, NH) have a smallish looking hitch that the specs say is "Class I". Since I'm used to the beefy hitch on the 8N, they look kinda chincy. Will my normal N equipment (blade and drag scoop) hook up to these ok?
JD
its CAT-1 . . . Dell (WA)
06-13-2003 12:03:05
 Re: Is a Class I hitch always a Class I? in reply to JD in SC, 06-13-2003 11:15:29
JD..... ...the N-Tractor set the specifications for 3-point hitches. Upon the expiration of Fergusons pattents, the American Society of Agriculture Engineers (ASAE) became the caretakers of 3-point hitches. Catagory 0, 1, 2, 3 are currently specified.
All catagory-1 hitches should be interchangeable because if they arn't, then they don't meet CAT-1 specs. Briefly, the top-pin is 3/4" and the bottom pins are 7/8".
Oh yeah, on the left/hand sidebar, under Research & Info is a listing called 3-Point Specs. You might want to do some research..... ...respectfully, Dell
JD in SC
06-13-2003 18:56:34
 Re: Re: Is a Class I hitch always a Class I? in reply to its CAT-1 . . . Dell (WA), 06-13-2003 12:03:05
Thanks, you know I never noticed that article on the sidebar. Very helpful.
JD
