Is there 2 or 3 springs on brake shoes
Brian in Windso
01-04-2001 19:09:58
Pulling brake shoes off 1950 8n and i had 2 springs on brake shoes.I have been reading archive posts and some talk of 3 springs .Which is correct and does any one have a pic of the setup that they could post? .. thks bt
Ed Gooding (VA)
01-05-2001 05:33:33
 Re: is there 2 or 3 springs on brake shoes in reply to Brian in Windsor Ontario, 01-04-2001 19:09:58
Hey Brian: see if this provides further help:
third party image
Happy New Year..... ..... ..... .Ed
'52 8N475798
01-05-2001 09:06:55
 Re: Re: is there 2 or 3 springs on brake shoes in reply to Ed Gooding (VA), 01-05-2001 05:33:33
Thanks for the great info guys but now a followup question. Why is there 2 springs on the right wheel and 3 on the left ??? thks bt
Hilltopper
01-05-2001 10:23:37
 Re: Re: Re: is there 2 or 3 springs on brake shoes in reply to Brian in Windsor Ontario, 01-05-2001 09:06:55
Probably due to the weight of the brake pedal or to keep brake from grabbing. Read it somewhere, but can't remember. (senior moments) :-)
Tyler (MD)
01-05-2001 03:36:21
This is off my 9N:
third party image
It's not the same but close. You should have 3 springs:
A secondary spring, a shoe retracting spring, and a brake adjusting spring. I'll scan a pic out of my parts manual for the 8N this evening if someone else hasn't helped you by then.
Take care,
Tyman
Pat In AZ
01-04-2001 19:53:45
There are two springs on the right and three on the left. The long stiff spring is in the front and the smaler one is in the rear. On the left side only there is a medium size spring that hooks to the top shoe same place as the big spring.The other end hooks in a hole in the front middle of the shoe suppot plate on the drumb side. Hope this makes since.
