Lift weak
Buckeye Fan
03-27-2003 18:53:13
My lift is weak and when it does make it up , it falls as soon as I push in the cluth. Will new piston rings fix it? I have the pump and cylinder out and intend to rebuild both while they are out. Are there any other components that I should be lookintg at? Who has the best rebuild kits? The fo4 shows the rings with all the gaps in line, is this an error, I would think they should be staggered. Thanks in advance, Buckeye.
Dell (WA)
03-27-2003 20:30:45
 Re: Lift weak in reply to Buckeye Fan, 03-27-2003 18:53:13
Buckeye..... ....do yourself a favor, replace your N-hydraulic lift piston with 3-iron rings with the better NAA-hydraulic lift piston and "O-rings". (pistons are interchangeable)
Its too late now, but you should have removed the 6" round dipstick plate and looked up inside your hydraulics for where the leaks are while operating.
There are 2 sources of leaks. The hydraulic piston/rings. OR... the hydraulic pump stand-pipe gasket under your seat. The stand-pipe is how you get hydrauic oil pumped from the bottom of the hydro-chamber up to the lift control lever arm under your seat..... ....Dell
Buckeye Fan, Thanks Dell
03-28-2003 04:45:37
 Re: Re: Lift weak in reply to Dell (WA), 03-27-2003 20:30:45
I will take your advice and go with the NAA piston, thanks for the help. Buckeye
