Is antifreeze permanent ?
Bill
12-29-2000 14:04:31
Does radiator antifreeze need to be changed and how often? What if you don't?
Thanks for your opinions.
Hilltopper
12-30-2000 07:35:16
 Re: Is antifreeze permanent ? in reply to Bill, 12-29-2000 14:04:31
Texaco makes a five year anti-freeze. Probably expensive.
Bill from MO
12-29-2000 20:14:14
If you really want to know if your coolant is corrosive or acidity, take volt meter, set to DC mv, touch one probe to tank and suspend other probe in antifreeze. A digtal volt meter works best. If their is a marginal volt reading you need to add an inhibator. If you use the older style volt meter, you may need to switch leads to get the right polarity. I have seen a volt meter read up to 2 volts on some car radiators. Back when raditors was metal!
Dave Todd
12-30-2000 10:08:33
 Re: Re: Is antifreeze permanent ? in reply to Bill from MO, 12-29-2000 20:14:14
I have heard something to that effect before, but thought it was just hipe to get you to buy more antifreeze. I have an aluminum radiator in my 40 Ford and was told to change the antifreeze every 2 or 3 years as it builds up a charge and then does some goofy stuff to the aluminum. Have had the car on the road for 11 years now and have only changed the antifreeze a couple times, and that was because I changed out the hoses, so decided to put in fresh antifreeze. I don't see anything wrong inside the radiator, so go figure.
dave
acadianbob
12-29-2000 20:07:56
hey bill, you really need to change your antifreeze; about every 3 years or so. it will always maintain its "antifreeze" properties as long as you don't dilute it. but, it WILL lose it's lubrication and, especially important, its anti-rust capability. i suppose you could always add lubricant and anti-rust chemicals; they are available. but i feel better flushing and replacing to get the "crap" out of there.
ZANE
12-29-2000 19:24:47
I have had the same antifreeze in my TO 20 Ferguson since 1965 and it was down to +10% last week and did fine. I check it along with all my other vehicles and it is alway down to about 0% like the rest.
..only ifyou drink it
12-29-2000 14:48:56
Lyle
12-29-2000 14:20:20
Bill, I believe permanent anti-freeze will last for years. I do believe that it's additives wears out though. What I do is add water pump lubricant to the radiator once a year. I have used antifreeze for 5 years without any problems.
