Grommet for Sherman Shift lever..
John C. Howell
01-20-2003 07:33:51
Has anyone had any experience with the rubber grommet for the sherman shifter lever.. I got one from Just 8n's.. Is a tight fit to install, and evern tighter fit to shift.. Does it take a while to break in.. Have been using in direct position due to problem getting in far enough to shift to high or low.. Does it need to be trimmed? Thanks
Willy-N
01-20-2003 09:14:37
 Re: Grommet for Sherman Shift lever.. in reply to John C. Howell, 01-20-2003 07:33:51
Put a couple of drops of brake fluid on it that will soften up the rubber on it. Mark H.
John C. Howell MT.
01-20-2003 09:17:20
 Re: Re: Grommet for Sherman Shift lever.. in reply to Willy-N, 01-20-2003 09:14:37
I'll try that thanks!
Willy-N
01-20-2003 09:20:40
 Re: Re: Re: Grommet for Sherman Shift lever.. in reply to John C. Howell MT., 01-20-2003 09:17:20
Watch how much you use it can remove paint too! Just a drop or 2 on the shaft going through the bushing. Mark H.
OH Boy
01-20-2003 08:05:08
I just put a little lube on mine and then it was fine.
John C. Howell MT.
01-20-2003 08:20:48
 Re: Re: Grommet for Sherman Shift lever.. in reply to OH Boy, 01-20-2003 08:05:08
I did lube mine installing it.. Problem is grommet restricts the shift lever from going in far enough to engage.. Possibly I don't have the grommet in far enough.. Surely no moisture will get thru them! John
David - OR
01-20-2003 12:57:55
 Re: Re: Re: Grommet for Sherman Shift lever.. in reply to John C. Howell MT., 01-20-2003 08:20:48
I think you have a combination Sherman. I suspect most of the repondents are speaking from experience with the much more common Sherman Step-Up. Perhaps the supplied grommet does not work well with the in/out motion needed for the combo, even though it works fine with the rotational motion needed for the step-up.
John C. Howell MT.
01-20-2003 13:05:00
 Re: Re: Re: Re: Grommet for Sherman Shift lever.. in reply to David - OR, 01-20-2003 12:57:55
You are right it is the combo..Have you tried the grommet in the combo? thanks jch
