Order Ford 8N Parts Online
Is 9N 2N, and 8N starter all the same?
VB .Ala.
01-01-2003 07:10:21
Is the starter on All N's the same? Have A friend who has A 9N and can't get starter to work. Will run off tractor, but when he puts it on the tractor It does nothing. He has had it in 3 or 4 different starter shops, and can find nothing wrong with it. VB Ala.
Mountainman
01-01-2003 09:47:30
 Re: Is 9N 2N, and 8N starter all the same? in reply to VB .Ala., 01-01-2003 07:10:21
Sounds like the classic poor ground connection to me. Check to make sure the starter case is grounding to the block and also check to make sure the ground cable from the battery is clean at both ends.
Are you using '0' or larger cables? You should be.
N - joy.
Mountainman...CA
Capt Jack
01-01-2003 09:19:27
I agree with Dell, what does do nothing mean? Remember these old tractors used big cables and the connection must be bright and shiny. If it works on the work bench then the problem is elsewhere in the starting system. Have you bypassed your starter switch?
Have a very good New Year
Dell (WA)
01-01-2003 08:46:08
VB..... .....according to my Ford Master Parts Catalog, Starter, 8N-110001, eff: all, 39-52.
That means you can use an 8N starter in a 9N/2N, but you can't use a 9N starter in an 8N because you can't mount the 8N starter solenoid on a 9N starter. (no holes).
You write..... .."but when he puts it on the tractor It does nothing"..... .define does nothing, maybe we can help..... ....Dell
