Order Ford 8N Parts Online
Is the 8N good for a brush hog
Scott S. Hess
09-25-2002 19:07:05
I have 5 acres that I need to mow. I'm considering buying a 1948 ford 8n that has been restored, My main use will be to mow the field to keep the weeds down. I would like to get a 4 foot bush hog. Is the 8N the right tractor for the job?
Thank You
Scott
Steve W
09-26-2002 05:30:40
 Re: Is the 8N good for a brush hog in reply to Scott S. Hesse, 09-25-2002 19:07:05
Get a 5 footer....the flywheel effect of the bigger blade really helps, and that extra foot makes a big difference in speed. If you get in too thick, just take half a swath. I have both a four footer and a five footer. I only use the four footer for uncharted territory (I beat on the poor thing) but with it's narrow width, you can't get close to fences, trees, etc.
Take Care
Steve
ThompsoN
09-26-2002 05:28:00
49 8N and 5' John Deere rotary mower.
I have about 10 acres and the combination works great.
Tom A
09-26-2002 03:50:46
I have a 48 8N with a 5' brushhog, and 20 very very hilly acres. Much of the land had been 'let go' for several years before I bought the place. I've hogged stuff I couldn't even walk through without problem. Got overconfident a few times and tried to hog some too-big trees, but I have taken down 2" diameter scrub saplings without even slowing down.
As everyone mentioned, get an ORC. I didn't have one for the first year (I'm cheap and stupid) but once I finally tried one I wouldn't hog without.
Tom
Dave OH
09-25-2002 20:38:53
Do yourself a favor and get a 5' Brush Hog. It will run it with no problem. As said Over Riding Clutch (ORC) is a must.
Dave OH
Sal
09-25-2002 19:26:20
I have a 51 and 52 8N that I hog with. I use a 5' hog and it does a great job.
I hog about 10-12 acres 2-3x's a year and have no problems. If I can drive over it I can cut it down.
HTH
-Sal
Jerry Ward
09-25-2002 19:24:06
I have a 9N and a 5' brush hog (Howze brand) and do not have any problem. Make sure you get a Over Running Coupler (ORC) for the PTO, otherwise when you step on the clutch you will get a big suprise. The flywheel effect of the 100 + pounds of blade will back feed through the PTO and keep you moving.
