Is it time for a new battery?
ED
12-07-2000 15:16:10
Just finished plowing snow - man I got to build some skids for the blade!
But here is my problem:
While plowing, I was running the lights. About 15 minutes into it, I noticed the lights were out. Being that it was close to dusk, I didn't notice if they went out all at once, or if they faded. So, I turned off the light switches and kept plowing.
When I was done, I turned on the lights and they came on at about 3/4 brightness. I surmized that the lights had drained the battery and that leaving the engine run put juice back inbto the battery. I turned off the engine, and tried to start it again. Nothing - no crank.
Is this a battery problem, or should I be fooling with that adjusting screw on the generator?
Jimp CO
12-07-2000 16:02:22
 Re: is it time for a new battery? in reply to ED, 12-07-2000 15:16:10
Ed, It could be that your lights were drawing too much current for the generator to handle or it could be that your battery isn't holding the charge very good.
I would recommend you charge up the battery, pull it out and get it checked with a load applied.
If it dosent hold, or shows bad, replace it.
It it is good, put it back in and run your N with the lights on and watch the ammeter to see if it continues to show a charge.. If it dosent't show charge, you may need to "tweek" the 3rd brush screw a tad.
Don't over do it tho;
I think you should be throwing about 8-10 amps into the battery (I'm sure someone will say for sure), but if there isn't enough to power your lights, they will drain the battery. Good luck.
raytasch
12-07-2000 17:54:24
 Re: Re: is it time for a new battery? in reply to Jimp CO, 12-07-2000 16:02:22
Make sure your generator belt is not slipping should be your first step. Measure across the + & - posts of the battery. Running should show an increase of at least 1 volt over static voltage. ray
